简介
Welcome to this guide on how to remove and replace the RAM (random access memory) in your Lenovo IdeaPad 3-1481W000NGUS. If the laptop is not turning on, there may be issues with the RAM, and it may be time to replace it. In this guide, we will walk you through the steps and tools needed to safely and effectively replace the memory module in a Lenovo IdeaPad 3-1481W000NGUS, so you can use your laptop without any memory-related issues.
Before attempting to replace the RAM, make sure that your laptop is completely shut down and unplugged from its power source or any other power outlets.
Prior to completing this guide, please visit our troubleshooting page, as memory-related issues can often be resolved without having to replace the RAM.
你所需要的
在这个步骤中使用的工具:Magnetic Project Mat$19.95
Orient the laptop so that the bottom is facing up.
Remove the six 7 mm screws using a Phillips #00 screwdriver.
Remove the four 4 mm screws using a Phillips #00 screwdriver.
