跳转到主内容
Lenovo IdeaPad 130S-11IGM Trackpad Replacement
你所需要的
  1. Lenovo IdeaPad 130S-11IGM Trackpad Replacement, Trackpad: 步骤 1 中的图像 1,2 Lenovo IdeaPad 130S-11IGM Trackpad Replacement, Trackpad: 步骤 1 中的图像 2,2
    • Power down the device and disconnect the power cable.
    • Remove the ten screws from the back panel using a T5 Torx screwdriver.
  2. Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 2 中的图像 2,2
    • Use an iFixit opening tool to detach the clips on the top side of the back panel.
    • After unclipping the top part of the panel, use your hands to gently unclip the rest of the panel.
    • Remove the back panel from the laptop.
  3. Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 3 中的图像 1,3 Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 3 中的图像 2,3 Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 3 中的图像 3,3
    • Unplug the battery connection from the motherboard.
    • This can be a little bit tricky; hold the wire of the plug and gently pull it. Alternatively, there is a small ridge at the edge of the battery connector, next to the wires which allows you to pry the connector out with a spudger.
  4. Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 4 中的图像 1,3 Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 4 中的图像 2,3 Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 4 中的图像 3,3
    • Remove the five screws from the battery using a Phillips #00 screwdriver.
    • Use your hands to remove the battery from the laptop.
  5. Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 5 中的图像 2,2
    • Use a pair of tweezers to lift the clip securing the touchpad cable.
    • Disconnect the touchpad cable from the motherboard.
  6. Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 6 中的图像 1,2 Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 6 中的图像 2,2
    • Remove the black tape hiding the screws on the trackpad.
    • Be careful when taking the tape off; try not to damage the other wires.
    • You will need the tape when reassembling the laptop.
  7. Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 7 中的图像 1,2 Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 7 中的图像 2,2
    • Remove the three screws holding the trackpad in place using a Phillips #00 screwdriver.
  8. Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 8 中的图像 1,3 Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 8 中的图像 2,3 Lenovo IdeaPad 130S-11IGM Trackpad Replacement: 步骤 8 中的图像 3,3
    • Lift the trackpad from the top side and remove it from the laptop.
结论
MD Yeasin Rahman Khan
于01/12/22注册
208 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 449
