跳转到主内容
Lenovo IdeaPad 110-15ISK Upper Case Replacement
你所需要的
  1. Lenovo IdeaPad 110-15ISK Upper Case Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Flip the IdeaPad bottom side up.
    • Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
    • Flip the computer back to top facing.
  2. Lenovo IdeaPad 110-15ISK Upper Case Replacement: 步骤 2 中的图像 1,1
    • Open the lid.
    • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
  3. Lenovo IdeaPad 110-15ISK Upper Case Replacement: 步骤 3 中的图像 1,1
    • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Completely remove the keyboard from the bottom assembly.
    • Unlock the ZIF conector before pulling the cable out
  4. Lenovo IdeaPad 110-15ISK Upper Case Replacement, Optical Drive: 步骤 5 中的图像 1,1
    • Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
  5. Lenovo IdeaPad 110-15ISK Upper Case Replacement: 步骤 6 中的图像 1,1
    • Flip the laptop to its back and the optical drive is located at the top left corner.
    • Remove the optical CD DVD drive by lightly pulling it out of the assembly.
  6. Lenovo IdeaPad 110-15ISK Upper Case Replacement, Upper Case: 步骤 7 中的图像 1,1
    • Place the laptop bottom facing up.
    • Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
  7. Lenovo IdeaPad 110-15ISK Upper Case Replacement: 步骤 8 中的图像 1,1
    • Separate the top case from the bottom using a plastic opening tool.
    • Continue prying the top and bottom case from each other all around the perimeter of the laptop.
结论
另外一个人完成了本指南。
Tyler
于10/17/18注册
597 声望
创作了3篇指南
团队
UW Tacoma, Team S1-G5, Rose Fall 2018 UW Tacoma, Team S1-G5, Rose Fall 2018 的会员
UWT-ROSE-F18S1G5
4 名成员
创作了39篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 37
总计 2,342
