简介
If the laptop is not showing any signs of turning on, then the battery may be loose or faulty. This device guide will show you how to remove the battery and secure it in place.
你所需要的
Flip the IdeaPad bottom side up.
Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
Flip the computer back to top facing.
Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
Place the laptop bottom facing up.
Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
4等其他人完成本指南。
