跳转到主内容
Lenovo IdeaPad 110-15IBR Optical Drive Replacement
你所需要的
  1. Lenovo IdeaPad 110-15IBR Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,2 Lenovo IdeaPad 110-15IBR Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 2,2
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source.
    • Using #1 Phillips screwdriver remove the 13 (9mmx6mm) screws holding the back.
    • Gently pry the back off using a plastic opening tool, starting from one of the corners.
  2. Lenovo IdeaPad 110-15IBR Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Using #1 Phillips screwdriver remove the 1 (9mmx6mm) screw holding the disk drive in place.
  3. Lenovo IdeaPad 110-15IBR Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Pull the optical drive away from device to slide out of dock.
    • Careful not to pull the drive straight up or towards the device, otherwise damage might be done to the drive connector.
结论
5等其他人完成本指南。
Saddam Alsinai
于10/18/17注册
669 声望
创作了4篇指南
团队
UW Tacoma, Team S3-G4, Liner Fall 2017 UW Tacoma, Team S3-G4, Liner Fall 2017 的会员
UWT-LINER-F17S3G4
4 名成员
创作了14篇指南
一条评论
I think there is an easier way to remove the optical drive. You only need to remove the screw in the middle near optical drive. After this you can pull out the otpical drive.
Max Härtwig - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 21
总计 3,638
