简介
If your computer won't boot and is having hard disk/hard drive reading errors, follow this guide to replace it. The guide shows how to remove the back from the device, unscrew the battery from the device, remove the drive from the dock, and unscrew the drive housing.
Place laptop with the bottom facing up. Using a Philip #1 screwdriver unscrew all 13 screws. Gently pry the back out using a plastic opening tool, starting from one of the corners.
To reassemble your device, follow these instructions in reverse order with your new replacement hard drive.
14等其他人完成本指南。
3条评论
Unplug or remove battery first?
Hard disk size?
you do not need to unplug or remove the battery
There are 3 more screws after removing dvd/cd drive
Mazwi Mbuso - 回复
