跳转到主内容
Lenovo IdeaPad 110-15IBR Hard Drive Replacement
你所需要的
  1. Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: 步骤 1 中的图像 1,2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: 步骤 1 中的图像 2,2
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source. Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode.
    • Place laptop with the bottom facing up. Using a Philip #1 screwdriver unscrew all 13 screws. Gently pry the back out using a plastic opening tool, starting from one of the corners.
  2. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the four (5mm) screws holding the hard drive in place.
  3. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Do not lift hard drive straight up otherwise you might risk breaking the connection port.
    • Gently slide the hard drive away and out out of the connection port.
  4. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Using a Philip #1 screwdriver remove 2 screws from each side, (removing 4 screws in total) holding the hard drive into the housing.
  5. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Remove hard drive from housing.
结论
To reassemble your device, follow these instructions in reverse order with your new replacement hard drive.
14等其他人完成本指南。
Saddam Alsinai
于10/18/17注册
687 声望
创作了4篇指南
团队
UW Tacoma, Team S3-G4, Liner Fall 2017 UW Tacoma, Team S3-G4, Liner Fall 2017 的会员
UWT-LINER-F17S3G4
4 名成员
创作了14篇指南
3条评论
Unplug or remove battery first?
Chris Quirke - 回复
you do not need to unplug or remove the battery
Holden Phillips - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 67
总计 20,238
