跳转到主内容
Lenovo IdeaPad 110-15IBR Display Replacement
你所需要的
  1. Lenovo IdeaPad 110-15IBR Display Replacement, Display: 步骤 1 中的图像 1,3 Lenovo IdeaPad 110-15IBR Display Replacement, Display: 步骤 1 中的图像 2,3 Lenovo IdeaPad 110-15IBR Display Replacement, Display: 步骤 1 中的图像 3,3
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source.
    • Using a plastic opening tool, gently pry the cover off of the display.
    • Lay screen flat down to remove the tabs from each corner.
  2. Lenovo IdeaPad 110-15IBR Display Replacement: 步骤 2 中的图像 1,1
    • Using the #1 Phillips head screwdriver unscrew the 4 (9mmx6mm) screws holding the screen in place.
  3. Lenovo IdeaPad 110-15IBR Display Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad 110-15IBR Display Replacement: 步骤 3 中的图像 2,2
    • Carefully lay the screen facing down on the keyboard.
    • Careful not to lift the screen to high up or tug on the screen due to a wire still being connected to the screen and display.
  4. Lenovo IdeaPad 110-15IBR Display Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad 110-15IBR Display Replacement: 步骤 4 中的图像 2,2
    • Remove the tape holding the connected wire to the display.
    • Gently remove the display wire from the connection.
    • Remove the display from the device.
结论
12等其他人完成本指南。
Saddam Alsinai
于10/18/17注册
669 声望
创作了4篇指南
团队
UW Tacoma, Team S3-G4, Liner Fall 2017 UW Tacoma, Team S3-G4, Liner Fall 2017 的会员
UWT-LINER-F17S3G4
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 5,081
