跳转到主内容
Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement
你所需要的
  1. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement, Back Case: 步骤 1 中的图像 1,1
    • Remove the thirteen 6 mm Phillips #0 screws.
  2. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 步骤 2 中的图像 2,2
    • Use an opening tool to gently disconnect most of the clips on the back panel.
    • DO NOT force the panel out towards the optical disk drive.
  3. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 步骤 3 中的图像 1,3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 步骤 3 中的图像 2,3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 步骤 3 中的图像 3,3
    • Pry the disk drive away from the center of the laptop.
    • Don't worry about any screws since we already removed the screws that are associated with the drive.
    • Once the drive is removed, remove the one 2 mm Phillips #0 screw that is now exposed.
  4. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 步骤 4 中的图像 1,3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 步骤 4 中的图像 2,3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 步骤 4 中的图像 3,3
    • Unclip any of the remaining clips and remove the back panel.
  5. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement, Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the four 6 mm Phillips #0 mounting screws.
  6. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 步骤 6 中的图像 1,3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 步骤 6 中的图像 2,3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 步骤 6 中的图像 3,3
    • Detach the wire connected to the motherboard and remove the battery assembly.
  7. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement, Hard Disk Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the four 4 mm Phillips #0 mounting screws attaching the caddy to the frame.
  8. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 步骤 8 中的图像 1,2 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 步骤 8 中的图像 2,2
    • Gently remove the caddy away from the motherboard.
    • If you are removing an already existing HDD, unplug the component along with the caddy and remove the four screws mounting the caddy to the HDD.
结论
Clark Beuckman
于02/22/22注册
529 声望
创作了5篇指南
团队
Clemson, Team 2-3, Hunter Spring 2022 Clemson, Team 2-3, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S2G3
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 15
总计 364
