跳转到主内容
Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement
你所需要的
  1. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement, USB/Headphones Jack: 步骤 1 中的图像 1,1
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: 步骤 2 中的图像 2,2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: 步骤 3 中的图像 1,1
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: 步骤 4 中的图像 1,1
    • Remove the three 4mm PH00 screws.
    • Unplug the ribbon wire connected to the USB/Headphone Jack PCB by lifting the black plastic tab holding the ribbon cable down.
    • Be extra careful not to bend the ribbon cable too much as it is fragile.
  5. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: 步骤 5 中的图像 2,2
    • Lift the USB/Headphone Jack PCB off of the board gently and put it to the side.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 836
