跳转到主内容
Lenovo IdeaPad 100s-14IBR Speaker Replacement
你所需要的
  1. Lenovo IdeaPad 100s-14IBR Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR Speaker Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad 100s-14IBR Speaker Replacement: 步骤 2 中的图像 2,2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR Speaker Replacement: 步骤 3 中的图像 1,1
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
    • Remove the six 4mm Phillips #00 screws.
    • Remove the battery using the nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR Speaker Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad 100s-14IBR Speaker Replacement: 步骤 4 中的图像 2,2
    • Unplug the speakers from the motherboard.
    • Remove the two 4mm PH00 screws from the metal shield on the trackpad.
    • Lift the metal shield up slightly, being very careful not to move the ribbon cables too much. Move the speaker cables out from under the shield.
  5. Lenovo IdeaPad 100s-14IBR Speaker Replacement: 步骤 5 中的图像 1,1
    • Lift the speakers from the case being careful of the wires connecting them. Put them to the side.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 394
