跳转到主内容
Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement
你所需要的
  1. Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement, Hard Drive/ Solid State Drive: 步骤 1 中的图像 1,1
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement: 步骤 2 中的图像 2,2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement: 步骤 3 中的图像 1,1
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with a nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the solid state drive.
结论
6等其他人完成本指南。
3条评论
WHAT DO i REPLACE THE ssd WITH ONCE REMOVED? I WANT TO UPGRADE TO A 1TB DRIVE. WHAT DO YOU SUGGEST FOR MY LENOVO 110S-141BR LAPTOP?
ROBERT GOFFINSKI - 回复
I replaced with an ssd but the laptop is not recognizing it
Janet Zinabe - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 35
过去 30 天: 119
总计 14,929
