跳转到主内容
Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement
你所需要的
  1. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement, Side Panel: 步骤 1 中的图像 1,1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: 步骤 2 中的图像 1,1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement, USB 3.0 Expansion Card: 步骤 3 中的图像 1,1
    • With your hands remove the 14mm screw that holds the cover on the back panel.
    • Gently pull the flap back to expose the expansion card retaining screw.
  4. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #2 to remove the 8mm screw that holds the USB 3.0 Expansion Card in place.
  5. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: 步骤 5 中的图像 1,1
    • With moderate force, pull straight up on the expansion card to remove it from the computer.
结论
3等其他人完成本指南。
Timothy Grebe
于10/19/14注册
1,634 声望
创作了9篇指南
团队
Cal Poly, Team 10-39, Amido Fall 2014 Cal Poly, Team 10-39, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G39
4 名成员
创作了18篇指南
一条评论
Why is a USB 3.1 Gen 1 adapter card called TV Tuner? It is an adapter card. What you connect to it is irelevant.
TheLOD2010 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 22
总计 1,129
