跳转到主内容
Lenovo IdeaCentre K410 RAM Module Replacement
你所需要的
  1. Lenovo IdeaCentre K410 RAM Module Replacement, Side Panel: 步骤 1 中的图像 1,1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 RAM Module Replacement: 步骤 2 中的图像 1,1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 RAM Module Replacement, RAM Module: 步骤 3 中的图像 1,1
    • Push down on the white clips on both sides of the memory module to release it.
    • Gently pull up on the memory module to remove it from the unit.
结论
When inserting the memory module, make sure that the notch on it aligns correctly with the key on the memory connector. Push the module straight down into the connector until the retaining clips close.
2等其他人完成本指南。
Timothy Grebe
于10/19/14注册
1,634 声望
创作了9篇指南
团队
Cal Poly, Team 10-39, Amido Fall 2014 Cal Poly, Team 10-39, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G39
4 名成员
创作了18篇指南
2条评论
sounds very hard to replace a ram “sarcastically“
you probley can replace a ram if you know what ram is so
remliv - 回复
But it is still good to have guides on everything
im glad that ifixit exists
remliv - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 28
总计 1,454
