跳转到主内容
Lenovo IdeaCentre K410 Motherboard Replacement
你所需要的
  1. Lenovo IdeaCentre K410 Motherboard Replacement, Side Panel: 步骤 1 中的图像 1,1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 Motherboard Replacement, USB 3.0 Expansion Card: 步骤 3 中的图像 1,1
    • With your hands remove the 14mm screw that holds the cover on the back panel.
    • Gently pull the flap back to expose the expansion card retaining screw.
  4. Lenovo IdeaCentre K410 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #2 to remove the 8mm screw that holds the USB 3.0 Expansion Card in place.
  5. Lenovo IdeaCentre K410 Motherboard Replacement: 步骤 5 中的图像 1,1
    • With moderate force, pull straight up on the expansion card to remove it from the computer.
  6. Lenovo IdeaCentre K410 Motherboard Replacement, RAM Module: 步骤 6 中的图像 1,1
    • Push down on the white clips on both sides of the memory module to release it.
    • Gently pull up on the memory module to remove it from the unit.
  7. Lenovo IdeaCentre K410 Motherboard Replacement, CPU Fan: 步骤 7 中的图像 1,1
    • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Be careful not to strip the screws.
  8. Lenovo IdeaCentre K410 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
  9. Lenovo IdeaCentre K410 Motherboard Replacement, Heat Sink: 步骤 9 中的图像 1,1
    • Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
    • The screws do not come all the way out of the heat sink
    • Pull the heat sink straight up to remove it.
  10. Lenovo IdeaCentre K410 Motherboard Replacement, CPU: 步骤 10 中的图像 1,2 Lenovo IdeaCentre K410 Motherboard Replacement, CPU: 步骤 10 中的图像 2,2
    • Remove the 2 8mm screws holding the CPU cover using a Torx #20 screwdriver.
    • Remove the 11 mm screw using a Torx #20 screwdriver.
    • Remove the cover and remove the CPU by gently pulling upward.
  11. Lenovo IdeaCentre K410 Motherboard Replacement, Motherboard: 步骤 11 中的图像 1,3 Lenovo IdeaCentre K410 Motherboard Replacement, Motherboard: 步骤 11 中的图像 2,3 Lenovo IdeaCentre K410 Motherboard Replacement, Motherboard: 步骤 11 中的图像 3,3
    • Unplug all cords attached to the motherboard.
    • The largest connection requires a significant amount of force to be removed.
  12. Lenovo IdeaCentre K410 Motherboard Replacement: 步骤 12 中的图像 1,2 Lenovo IdeaCentre K410 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Remove all 6 8mm screws attaching the motherboard to the base of the tower using a Phillips #2 screwdriver.
    • Gently pull the motherboard from the unit.
结论
11等其他人完成本指南。
Timothy Grebe
于10/19/14注册
1,634 声望
创作了9篇指南
团队
Cal Poly, Team 10-39, Amido Fall 2014 Cal Poly, Team 10-39, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G39
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 61
总计 5,391
