跳转到主内容
Lenovo IdeaCentre K410 Heat Sink Replacement
你所需要的
  1. Lenovo IdeaCentre K410 Heat Sink Replacement, Side Panel: 步骤 1 中的图像 1,1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 Heat Sink Replacement: 步骤 2 中的图像 1,1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 Heat Sink Replacement, CPU Fan: 步骤 3 中的图像 1,1
    • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Be careful not to strip the screws.
  4. Lenovo IdeaCentre K410 Heat Sink Replacement: 步骤 4 中的图像 1,1
    • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
  5. Lenovo IdeaCentre K410 Heat Sink Replacement, Heat Sink: 步骤 5 中的图像 1,1
    • Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
    • The screws do not come all the way out of the heat sink
    • Pull the heat sink straight up to remove it.
结论
Timothy Grebe
于10/19/14注册
1,634 声望
创作了9篇指南
团队
Cal Poly, Team 10-39, Amido Fall 2014 Cal Poly, Team 10-39, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G39
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 807
