你所需要的
Lay the computer down on its side as shown.
Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
Pull the heat sink straight up to remove it.
即将完成!
结论
15等其他人完成本指南。
