跳转到主内容
Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement
你所需要的
  1. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Stand Base: 步骤 1 中的图像 1,1
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 步骤 2 中的图像 2,2
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Back Cover: 步骤 3 中的图像 1,1
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 步骤 4 中的图像 1,3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 步骤 4 中的图像 2,3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 步骤 4 中的图像 3,3
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 步骤 5 中的图像 2,2
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Arm Stand: 步骤 6 中的图像 1,2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Arm Stand: 步骤 6 中的图像 2,2
    • Remove the four screws that secure the arm stand.
  7. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 步骤 7 中的图像 1,2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 步骤 7 中的图像 2,2
    • Lift up to remove the arm stand.
  8. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, EMI Cover: 步骤 8 中的图像 1,3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, EMI Cover: 步骤 8 中的图像 2,3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, EMI Cover: 步骤 8 中的图像 3,3
    • Remove the 5 screws that secure the EMI cover.
    • Remove the cover.
  9. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Power Switch Board: 步骤 9 中的图像 1,1
    • Locate the power switch board and the tan colored tab on it holding the blue and white ribbon cable down.
  10. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 步骤 10 中的图像 1,1
    • Pull the tab towards the blue and white ribbon cable to open it. Pull the cable out of the power switch board.
  11. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 步骤 11 中的图像 1,2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 步骤 11 中的图像 2,2
    • Slide the power switch cable out of its slot in the direction shown, making sure to lift up the end carefully.
结论
另外一个人完成了本指南。
Jackson Blake
于01/22/18注册
1,119 声望
创作了9篇指南
团队
Cal Poly, Team S16-G3, Banghart Winter 2018 Cal Poly, Team S16-G3, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S16G3
4 名成员
创作了9篇指南
一条评论
Hello
I have a similar problem on a Lenovo AiO 510-22ISH, how can i check if the power button board is really broken down?
After sales service said that was the problem but how can i test it?
Thank You
Fred - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 14
总计 1,389
