跳转到主内容
Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement
你所需要的
  1. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Stand Base: 步骤 1 中的图像 1,1
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Back Cover: 步骤 3 中的图像 1,1
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 步骤 4 中的图像 1,3 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 步骤 4 中的图像 2,3 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 2,2
    • Unscrew the four screws that secure the hard drive enclosure.
  7. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Unplug the SATA cable. Lift to remove the hard drive enclosure.
  8. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 步骤 8 中的图像 1,2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Unscrew the four screws that hold hard drive enclosure to the hard drive, located on the side of the enclosure.
  9. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Lift the hard drive up to remove it from the enclosure.
结论
12等其他人完成本指南。
Jackson Blake
于01/22/18注册
1,119 声望
创作了9篇指南
团队
Cal Poly, Team S16-G3, Banghart Winter 2018 Cal Poly, Team S16-G3, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S16G3
4 名成员
创作了9篇指南
5条评论
you have been busy!!!!! Noticed the solutions , etc. below and that is impressive. chaosone7 @gmail.com
Bobby Kincannon - 回复
It’s nice and easy to get there, unfortunately the board was fried lol.
Charles Allen - 回复
Can I replace the hard drive with a 1TB SATA III 6Gb/s 4-bit QLC V-NAND Flash 1GB Cache 2.5" Solid State Drive - Samsung QVO
Donna Briggs - 回复
The hard drive in this should be a 2.5” drive, so the replacement you listed should work
Jackson Blake -
Do you have a better suggestion
Donna Briggs - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 79
总计 15,934
