跳转到主内容
Lenovo Horizon 2s Rear Case Replacement
你所需要的
  1. Lenovo Horizon 2s Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,3 Lenovo Horizon 2s Rear Case Replacement, Rear Case: 步骤 1 中的图像 2,3 Lenovo Horizon 2s Rear Case Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Flip the device so the rear case is facing upward.
    • With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
  2. Lenovo Horizon 2s Rear Case Replacement: 步骤 2 中的图像 1,2 Lenovo Horizon 2s Rear Case Replacement: 步骤 2 中的图像 2,2
    • Using your fingers, carefully remove the rubber boot from the right side of the rear case.
    • With the Phillips #1 head, remove the screw placed directly under the rubber boot.
  3. Lenovo Horizon 2s Rear Case Replacement: 步骤 3 中的图像 1,1
    • Using the plastic opening tool, push the display screen on the device forward until it separates from the rear casing.
  4. Lenovo Horizon 2s Rear Case Replacement: 步骤 4 中的图像 1,1
    • Using the plastic opening tool, carefully pry around the perimeter of the screen until the entire screen is completely separated from the rear casing.
  5. Lenovo Horizon 2s Rear Case Replacement: 步骤 5 中的图像 1,3 Lenovo Horizon 2s Rear Case Replacement: 步骤 5 中的图像 2,3 Lenovo Horizon 2s Rear Case Replacement: 步骤 5 中的图像 3,3
    • Before completely separating the screen from the rear casing you will carefully detach two wires that are connected to both sides of the device. This will allow you to completely separate the rear casing from screen.
结论
另外一个人完成了本指南。
Zak Kazakos
于09/25/17注册
320 声望
创作了3篇指南
团队
USF Tampa, Team S3-G6, Cannon Fall 2017 USF Tampa, Team S3-G6, Cannon Fall 2017 的会员
USFT-CANNON-F17S3G6
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 1,016
