简介
Use this guide to replace a faulty motherboard in your two-in-one tablet.
This guide will show you how to remove the rear casing of your tablet and how to remove all of the internal components.
你所需要的
Flip the device so the rear case is facing upward.
With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
Using your fingers carefully and slowly disconnect the wire shown here from the motherboard.
Locate the intertwined black and red wires that connect the two small, black speakers and the motherboard, as shown in the picture.
Disconnect this wire from the motherboard by carefully pulling it out.
With the Phillips #1 head, remove the M2-6mm screw securing the network card.
Carefully remove by sliding the network card out from the motherboard.
Carefully remove the wires connecting to the network card with light pressure.
2条评论
Thank you! This was very helpful and easy to follow
This is great and illustrated well. Did you by any chance see where the CMOS battery is located?
