跳转到主内容
Lenovo G780 Screen Replacement
你所需要的
  1. Lenovo G780 Screen Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo G780 Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off the computer.
    • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
  2. Lenovo G780 Screen Replacement: 步骤 2 中的图像 1,1
    • Hold the battery release switch in the unlocked position and remove the battery.
  3. Lenovo G780 Screen Replacement, Screen: 步骤 3 中的图像 1,2 Lenovo G780 Screen Replacement, Screen: 步骤 3 中的图像 2,2
    • Using the metal spudger, peel back the adhesive-backed bumpers on the bottom left and right corners of the screen.
  4. Lenovo G780 Screen Replacement: 步骤 4 中的图像 1,3 Lenovo G780 Screen Replacement: 步骤 4 中的图像 2,3 Lenovo G780 Screen Replacement: 步骤 4 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove both 5.5mm screws from the corners of the screen.
  5. Lenovo G780 Screen Replacement: 步骤 5 中的图像 1,3 Lenovo G780 Screen Replacement: 步骤 5 中的图像 2,3 Lenovo G780 Screen Replacement: 步骤 5 中的图像 3,3
    • Using an iFixit opening tool, start prying on the top face cover on the screen by applying pressure near the bottom of the screen.
    • Once the face cover has started to come away from the screen, begin pulling away with both hands until the whole face cover has been removed from the screen.
    • Be careful not to break the thin plastic cover.
  6. Lenovo G780 Screen Replacement: 步骤 6 中的图像 1,3 Lenovo G780 Screen Replacement: 步骤 6 中的图像 2,3 Lenovo G780 Screen Replacement: 步骤 6 中的图像 3,3
    • Remove the four 8.5mm screws on the corners of the screen that connect the screen frame to the back cover.
  7. Lenovo G780 Screen Replacement: 步骤 7 中的图像 1,2 Lenovo G780 Screen Replacement: 步骤 7 中的图像 2,2
    • With the back cover being removed from the screen frame, the back cover can be set aside.
  8. Lenovo G780 Screen Replacement: 步骤 8 中的图像 1,3 Lenovo G780 Screen Replacement: 步骤 8 中的图像 2,3 Lenovo G780 Screen Replacement: 步骤 8 中的图像 3,3
    • Carefully remove the clear adhesive tape holding the cable down, being careful not to damage the small wires under the tape.
    • Once the tape has been removed, the ribbon connector will pull away from the back of screen.
  9. Lenovo G780 Screen Replacement: 步骤 9 中的图像 1,3 Lenovo G780 Screen Replacement: 步骤 9 中的图像 2,3 Lenovo G780 Screen Replacement: 步骤 9 中的图像 3,3
    • Remove the eight, 3mm screws around the screen frame. There will be four on each side of the screen frame.
    • With the screws removed the screen will be free to be lifted away from the screen frame.
结论
另外一个人完成了本指南。
Riley Griffin
于03/25/19注册
316 声望
创作了3篇指南
团队
IUPUI, Team S2-G4, Henning Spring 2019 IUPUI, Team S2-G4, Henning Spring 2019 的会员
IUPUI-HENNING-S19S2G4
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 996
