简介
This guide gives a step-by-step instructions for the removal and replacement of a CD drive for a Lenovo laptop, model G70-80. Following the directions outlined below should take approximated five minutes from beginning to completion. The end outcome is a working CD drive for the Lenovo laptop, model G70-80.
你所需要的
Locate a Phillips head screwdriver. Use the screwdriver to remove the 2 screws found on the backside of the Lenovo G70-80. Once both of these screws are removed you will be able to remove the back of the laptop.
Reassembly should be equally as easy as the disassembly. Follow the directions step by step in reverse order to reassemble the Lenovo G70-80 with your new CD drive.
另外一个人完成了本指南。
