跳转到主内容
Lenovo G575 Fan Replacement
你所需要的
  1. Lenovo G575 Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Use the two switches to the left of and below the battery to unlock and release the battery.
    • The switch on the left should be moved to the left to unlock, then the switch on the right will release the battery.
    • Remove the battery from the laptop by lifting it out from its bay.
  2. Lenovo G575 Fan Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the five screws from the service panel on the right side.
    • Lift up the service panel.
  3. Lenovo G575 Fan Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the three silver screws holding the fan down.
    • Pull out the fan cable from its connector on the motherboard.
    • Lift the fan out of the case.
结论
Samson Wong
于09/21/20注册
103 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 872
