跳转到主内容
简介
At some point in your lifetime, you'll probably end up in this situation: You own a perfectly good laptop, but you've broken the screen! By utilizing this guide, you can save yourself time and money while learning more about your computer! This guide will explain, step-by-step, how to replace the screen in your Lenovo G570 notebook computer.
配件
没有特定配件。
  1. Lenovo G570: Screen Replacement, Before You Begin...: 步骤 1 中的图像 1,1
    • Order a replacement screen for your laptop! Screens for this laptop (and almost any other model) can be found at https://www.laptopscreen.com/.
    • Be careful to order the right type of screen! There are two types, LED and CCFL. If you aren't sure which type your laptop screen is, wait to order the screen until you reach step 7, so that you can verify what type your computer has.
    • Before working on your laptop, check the warranty terms. If the machine is still under warranty, working on it yourself may void the warranty.
  2. Lenovo G570: Screen Replacement, Prepare Your Workspace...: 步骤 2 中的图像 1,1
    • Gather the necessary tools, and make sure you have a large open space (such as a workbench) to work on.
  3. Lenovo G570: Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the 2 rubber bumpers which cover the screws. (They are located on the bottom left and right corners of the bezel.)
    • Then, using your small Philips-head screwdriver, remove the 2 screws which were just uncovered.
  4. Lenovo G570: Screen Replacement: 步骤 4 中的图像 1,2 Lenovo G570: Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the front plastic bezel from the screen using the following steps.
    • Pry up the bezel in the location depicted with a plastic opening tool or small flat-head screwdriver until you free the first few retaining clips.
    • Once a few clips are loosened, you can pry the bezel the rest of the way off by hand.
    • To do so, pull each side of the bezel outward and towards the center of the screen, until all of the retaining clips have been released.
  5. Lenovo G570: Screen Replacement: 步骤 5 中的图像 1,3 Lenovo G570: Screen Replacement: 步骤 5 中的图像 2,3 Lenovo G570: Screen Replacement: 步骤 5 中的图像 3,3
    • Remove the four screws (one in each corner) which attach the screen to the lid.
  6. Lenovo G570: Screen Replacement: 步骤 6 中的图像 1,1
    • Carefully pull the lid away from the screen, while keeping in mind that there are cables attached to the lid as well as the screen.
    • The lid will separate from the screen, but the cables will not. Lean it against something to avoid stressing the cables.
  7. Lenovo G570: Screen Replacement: 步骤 7 中的图像 1,1
    • Now, detach the video cable from the back of the screen.
    • Proceed with caution, as the video cable is very easily damaged!
  8. Lenovo G570: Screen Replacement: 步骤 8 中的图像 1,2 Lenovo G570: Screen Replacement: 步骤 8 中的图像 2,2
    • Remove the 8 screws (4 on each side) which attach the hinges to the screen
  9. Lenovo G570: Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the screen, and recycle it at your local dump or recycling center
  10. Lenovo G570: Screen Replacement, Time to replace the screen!: 步骤 10 中的图像 1,2 Lenovo G570: Screen Replacement, Time to replace the screen!: 步骤 10 中的图像 2,2
    • Before you begin, be sure to put something on the keyboard to protect the screen from being scratched
  11. Lenovo G570: Screen Replacement: 步骤 11 中的图像 1,1
    • Position the screen face-down on the keyboard, and line up the hinges with the holes on either side of the screen
    • Using your Philips-head screwdriver, replace the 8 screws (4 on each side)
  12. Lenovo G570: Screen Replacement: 步骤 12 中的图像 1,1
    • Connect the video cable!
    • Be careful not to damage the cable, or to touch the base of the circuit board on the monitor
  13. Lenovo G570: Screen Replacement: 步骤 13 中的图像 1,1
    • Lift the plastic lid up to the back of the screen, and press them together so that lid now hinges with the screen
    • Be careful that the cables which run along the bottom inside edge of the lid are not squished by the screen when you bring the screen and lid together!
  14. Lenovo G570: Screen Replacement: 步骤 14 中的图像 1,1
    • Replace the four screws that hold the screen and lid together
    • Snap the plastic bezel on, and replace the two screws which connect the bezel to the computer (reference step 4 for clarification)
  15. Lenovo G570: Screen Replacement, You're done!: 步骤 15 中的图像 1,1
    • Boot up your laptop and check to see if the new screen is working- if not, go back to step 12 and ensure you reconnected the video cable correct and without damage
终点
14等其他人完成本指南。
Alex Pfadenhauer
于2012年10月02日注册
651 声望分
撰写一个指南
一条评论
You should mention in step 7 how to recognise if screen is LED or CCFL.
Paweł Kasztura - 回复
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 27
过去的30天: 88
总计 39,737
