跳转到主内容
Lenovo G50-80 80E5 Removing top panel Replacement
你所需要的
  1. Lenovo G50-80 80E5 Removing top panel Replacement, Battery: 步骤 1 中的图像 1,1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 2 中的图像 1,3 Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 2 中的图像 2,3 Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 2 中的图像 3,3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 3 中的图像 1,3 Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 3 中的图像 2,3 Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 3 中的图像 3,3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 4 中的图像 1,3 Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 4 中的图像 2,3 Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 4 中的图像 3,3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: 步骤 5 中的图像 1,2 Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: 步骤 5 中的图像 2,2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 6 中的图像 1,2 Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 6 中的图像 2,2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: 步骤 7 中的图像 1,3 Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: 步骤 7 中的图像 2,3 Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: 步骤 7 中的图像 3,3
    • Locate the 3 screws on the bottom, securing the keyboard.
    • One Screw will be located under Lenovo sticker. Break sticker to gain access to screw.
  8. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 8 中的图像 1,1
    • Starting on side, gently pry up using spudge.
  9. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 9 中的图像 1,2 Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 9 中的图像 2,2
    • Continue prying around top of keyboard
  10. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 10 中的图像 1,1
    • Once the top of keyboard is loose, gently lift up
  11. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 11 中的图像 1,1
    • lift up bottom of keyboard slightly, to access keyboard ribbon
  12. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 12 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, lift up clip to remove keyboard ribbon cable.
  13. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 13 中的图像 1,2 Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 13 中的图像 2,2
    • Keyboard ribbon cable removed
    • Once ribbon is removed, keyboard can be lifted out
  14. Lenovo G50-80 80E5 Removing top panel Replacement, Removing top panel: 步骤 14 中的图像 1,1
    • Remove wifi wires by lifting up
  15. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 15 中的图像 1,1
    • locate power and monitor cable on bottom side next to fan
  16. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 16 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • remove power cable with tweezers by gently pullying
  17. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 17 中的图像 1,1
    • remove monitor cable by gently pulling on tab straight up
  18. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 18 中的图像 1,1
    • Monitor and power cable disconnected
  19. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 19 中的图像 1,1
    • Disconnect the fan wires from the motherboard by lifting upwards
  20. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 20 中的图像 1,3 Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 20 中的图像 2,3 Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 20 中的图像 3,3
    • Locate the 3 screws holding fan in place
    • Remove 3 screws
    • fan should lift out of place
  21. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 21 中的图像 1,1
    • lift clip to remove ribbon cable for think pad.
  22. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 22 中的图像 1,2 Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 22 中的图像 2,2
    • lift clip to remove power button ribbon cable.
  23. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 23 中的图像 1,1
    • Begin by locating screws on bottom panel
  24. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 24 中的图像 1,1
    • Remove screws using a 001 phillips screw driver.
  25. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 25 中的图像 1,3 Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 25 中的图像 2,3 Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 25 中的图像 3,3
    • Once screws are removed, begin by gently prying up in one corner using a spudge
    • Continue to center and then around to opposite side.
    • once all sides have been pried open, lift top half off
  26. Lenovo G50-80 80E5 Removing top panel Replacement: 步骤 26 中的图像 1,1
    • Top covered removed
结论
12等其他人完成本指南。
Victor
于10/17/17注册
1,282 声望
创作了4篇指南
团队
UMass Dartmouth, Team S1-G6, Simcock Fall 2017 UMass Dartmouth, Team S1-G6, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 62
总计 7,438
