跳转到主内容
Lenovo G50-80 80E5 Power Button Replacement
你所需要的
  1. Lenovo G50-80 80E5 Power Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Power Button Replacement: 步骤 2 中的图像 1,3 Lenovo G50-80 80E5 Power Button Replacement: 步骤 2 中的图像 2,3 Lenovo G50-80 80E5 Power Button Replacement: 步骤 2 中的图像 3,3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Power Button Replacement: 步骤 3 中的图像 1,3 Lenovo G50-80 80E5 Power Button Replacement: 步骤 3 中的图像 2,3 Lenovo G50-80 80E5 Power Button Replacement: 步骤 3 中的图像 3,3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Power Button Replacement: 步骤 4 中的图像 1,3 Lenovo G50-80 80E5 Power Button Replacement: 步骤 4 中的图像 2,3 Lenovo G50-80 80E5 Power Button Replacement: 步骤 4 中的图像 3,3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Power Button Replacement, Bottom Access Panel: 步骤 5 中的图像 1,2 Lenovo G50-80 80E5 Power Button Replacement, Bottom Access Panel: 步骤 5 中的图像 2,2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Power Button Replacement: 步骤 6 中的图像 1,2 Lenovo G50-80 80E5 Power Button Replacement: 步骤 6 中的图像 2,2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Power Button Replacement, Keyboard: 步骤 7 中的图像 1,3 Lenovo G50-80 80E5 Power Button Replacement, Keyboard: 步骤 7 中的图像 2,3 Lenovo G50-80 80E5 Power Button Replacement, Keyboard: 步骤 7 中的图像 3,3
    • Locate the 3 screws on the bottom, securing the keyboard.
    • One Screw will be located under Lenovo sticker. Break sticker to gain access to screw.
  8. Lenovo G50-80 80E5 Power Button Replacement: 步骤 8 中的图像 1,1
    • Starting on side, gently pry up using spudge.
  9. Lenovo G50-80 80E5 Power Button Replacement: 步骤 9 中的图像 1,2 Lenovo G50-80 80E5 Power Button Replacement: 步骤 9 中的图像 2,2
    • Continue prying around top of keyboard
  10. Lenovo G50-80 80E5 Power Button Replacement: 步骤 10 中的图像 1,1
    • Once the top of keyboard is loose, gently lift up
  11. Lenovo G50-80 80E5 Power Button Replacement: 步骤 11 中的图像 1,1
    • lift up bottom of keyboard slightly, to access keyboard ribbon
  12. Lenovo G50-80 80E5 Power Button Replacement: 步骤 12 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, lift up clip to remove keyboard ribbon cable.
  13. Lenovo G50-80 80E5 Power Button Replacement: 步骤 13 中的图像 1,2 Lenovo G50-80 80E5 Power Button Replacement: 步骤 13 中的图像 2,2
    • Keyboard ribbon cable removed
    • Once ribbon is removed, keyboard can be lifted out
  14. Lenovo G50-80 80E5 Power Button Replacement, Removing top panel: 步骤 14 中的图像 1,1
    • Remove wifi wires by lifting up
  15. Lenovo G50-80 80E5 Power Button Replacement: 步骤 15 中的图像 1,1
    • locate power and monitor cable on bottom side next to fan
  16. Lenovo G50-80 80E5 Power Button Replacement: 步骤 16 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • remove power cable with tweezers by gently pullying
  17. Lenovo G50-80 80E5 Power Button Replacement: 步骤 17 中的图像 1,1
    • remove monitor cable by gently pulling on tab straight up
  18. Lenovo G50-80 80E5 Power Button Replacement: 步骤 18 中的图像 1,1
    • Monitor and power cable disconnected
  19. Lenovo G50-80 80E5 Power Button Replacement: 步骤 19 中的图像 1,1
    • Disconnect the fan wires from the motherboard by lifting upwards
  20. Lenovo G50-80 80E5 Power Button Replacement: 步骤 20 中的图像 1,3 Lenovo G50-80 80E5 Power Button Replacement: 步骤 20 中的图像 2,3 Lenovo G50-80 80E5 Power Button Replacement: 步骤 20 中的图像 3,3
    • Locate the 3 screws holding fan in place
    • Remove 3 screws
    • fan should lift out of place
  21. Lenovo G50-80 80E5 Power Button Replacement: 步骤 21 中的图像 1,1
    • lift clip to remove ribbon cable for think pad.
  22. Lenovo G50-80 80E5 Power Button Replacement: 步骤 22 中的图像 1,2 Lenovo G50-80 80E5 Power Button Replacement: 步骤 22 中的图像 2,2
    • lift clip to remove power button ribbon cable.
  23. Lenovo G50-80 80E5 Power Button Replacement: 步骤 23 中的图像 1,1
    • Begin by locating screws on bottom panel
  24. Lenovo G50-80 80E5 Power Button Replacement: 步骤 24 中的图像 1,1
    • Remove screws using a 001 phillips screw driver.
  25. Lenovo G50-80 80E5 Power Button Replacement: 步骤 25 中的图像 1,3 Lenovo G50-80 80E5 Power Button Replacement: 步骤 25 中的图像 2,3 Lenovo G50-80 80E5 Power Button Replacement: 步骤 25 中的图像 3,3
    • Once screws are removed, begin by gently prying up in one corner using a spudge
    • Continue to center and then around to opposite side.
    • once all sides have been pried open, lift top half off
  26. Lenovo G50-80 80E5 Power Button Replacement: 步骤 26 中的图像 1,1
    • Top covered removed
  27. Lenovo G50-80 80E5 Power Button Replacement, Power Button: 步骤 27 中的图像 1,2 Lenovo G50-80 80E5 Power Button Replacement, Power Button: 步骤 27 中的图像 2,2
    • At this point in disassembly, there will be one #00x5.5 mm screw securing the power button board in place.
    • Take your screwdriver and remove the screw.
  28. Lenovo G50-80 80E5 Power Button Replacement: 步骤 28 中的图像 1,3 Lenovo G50-80 80E5 Power Button Replacement: 步骤 28 中的图像 2,3 Lenovo G50-80 80E5 Power Button Replacement: 步骤 28 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Take your tweezers and grip the power button board.
    • Using tweezers, lift power button board up and out. The cable wire for the power button board should be disconnected at this point and the piece should lift out without any extra work needed.
结论
2等其他人完成本指南。
Abigail Hood
于10/17/17注册
387 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G6, Simcock Fall 2017 UMass Dartmouth, Team S1-G6, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 28
总计 3,571
