跳转到主内容
Lenovo G50-80 80E5 Hard Drive Replacement
你所需要的
  1. Lenovo G50-80 80E5 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Hard Drive Replacement: 步骤 2 中的图像 1,3 Lenovo G50-80 80E5 Hard Drive Replacement: 步骤 2 中的图像 2,3 Lenovo G50-80 80E5 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Hard Drive Replacement: 步骤 3 中的图像 1,3 Lenovo G50-80 80E5 Hard Drive Replacement: 步骤 3 中的图像 2,3 Lenovo G50-80 80E5 Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Hard Drive Replacement: 步骤 4 中的图像 1,3 Lenovo G50-80 80E5 Hard Drive Replacement: 步骤 4 中的图像 2,3 Lenovo G50-80 80E5 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Hard Drive Replacement, Bottom Access Panel: 步骤 5 中的图像 1,2 Lenovo G50-80 80E5 Hard Drive Replacement, Bottom Access Panel: 步骤 5 中的图像 2,2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Hard Drive Replacement: 步骤 6 中的图像 1,2 Lenovo G50-80 80E5 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,1
    • Rotate the laptop until you are positioned over the hard drive.
  8. Lenovo G50-80 80E5 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Use the #00 Phillips screwdriver to remove the four 5.5mm screws around the hard drive.
  9. Lenovo G50-80 80E5 Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Slide the hard drive towards yourself and remove it.
结论
If you would like to reassemble your device, please follow these instructions in reverse order.
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 776
