跳转到主内容
Lenovo G50-80 80E5 Battery Replacement
  1. Lenovo G50-80 80E5 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Battery Replacement: 步骤 2 中的图像 1,3 Lenovo G50-80 80E5 Battery Replacement: 步骤 2 中的图像 2,3 Lenovo G50-80 80E5 Battery Replacement: 步骤 2 中的图像 3,3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Battery Replacement: 步骤 3 中的图像 1,3 Lenovo G50-80 80E5 Battery Replacement: 步骤 3 中的图像 2,3 Lenovo G50-80 80E5 Battery Replacement: 步骤 3 中的图像 3,3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Battery Replacement: 步骤 4 中的图像 1,3 Lenovo G50-80 80E5 Battery Replacement: 步骤 4 中的图像 2,3 Lenovo G50-80 80E5 Battery Replacement: 步骤 4 中的图像 3,3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
结论
4等其他人完成本指南。
Abigail Hood
于10/17/17注册
387 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G6, Simcock Fall 2017 UMass Dartmouth, Team S1-G6, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G6
4 名成员
创作了10篇指南
一条评论
I purchased a new battery. I think I have not put the new one correctly. It does not align right. The computer is working fine. But it does not charge until I place a couple of books under the battery case, to kind of keep it in place..
Ashish Nelson - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 37
总计 4,587
