跳转到主内容
Lenovo G40-30 LCD Screen Replacement
你所需要的
  1. Lenovo G40-30 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo G40-30 LCD Screen Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo G40-30 LCD Screen Replacement, Battery: 步骤 1 中的图像 3,3
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 LCD Screen Replacement: 步骤 2 中的图像 1,3 Lenovo G40-30 LCD Screen Replacement: 步骤 2 中的图像 2,3 Lenovo G40-30 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 1,2 Lenovo G40-30 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to pry the plastic away from the screen.
  5. Lenovo G40-30 LCD Screen Replacement: 步骤 5 中的图像 1,2 Lenovo G40-30 LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Carefully unsnap the front plastic piece to expose the frame of the screen.
  6. Lenovo G40-30 LCD Screen Replacement: 步骤 6 中的图像 1,3 Lenovo G40-30 LCD Screen Replacement: 步骤 6 中的图像 2,3 Lenovo G40-30 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Unscrew the four 7mm screws located on all four corners of the frame using a JIS #0 screwdriver.
    • Carefully lift the screen from the base so as to not damage it.
  7. Lenovo G40-30 LCD Screen Replacement: 步骤 7 中的图像 1,2 Lenovo G40-30 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Slowly remove the sticker connected to the rear of the screen using a spudger.
    • Carefully disconnect the screen from the base of the laptop.
  8. Lenovo G40-30 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Now you have removed the screen and are ready to install a new one.
结论
2等其他人完成本指南。
Jimmy McClenan
于02/08/18注册
156 声望
撰写一个指南
团队
2指南评论
Thanks alot…..I just fixed my screen by God's grace.
Nnaemeka Okechukwu - 回复
Hi! Is it possible to replace the screen with 1080p LCD?
Chin Yau Chia - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 2,750
