跳转到主内容
Lenovo Flex 6-11IGM Motherboard Replacement
你所需要的
  1. Lenovo Flex 6-11IGM Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Motherboard Replacement: 步骤 2 中的图像 1,2 Lenovo Flex 6-11IGM Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Motherboard Replacement: 步骤 3 中的图像 1,1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Motherboard Replacement: 步骤 4 中的图像 1,2 Lenovo Flex 6-11IGM Motherboard Replacement: 步骤 4 中的图像 2,2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. 注意:步骤 5-7 源自标记为进行中的 指南
    Lenovo Flex 6-11IGM Motherboard Replacement, RAM: 步骤 5 中的图像 1,2 Lenovo Flex 6-11IGM Motherboard Replacement, RAM: 步骤 5 中的图像 2,2
    • Insert a plastic opening pick in the ribbon cable housing, flip the black part up, and pull the cable out with your fingers.
  6. Lenovo Flex 6-11IGM Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the four 3.5mm Phillips #0 screws that secure the heat sink.
    • Remove the four 3.5 mm Phillips #0 screws that secure the heat sink.
  7. Lenovo Flex 6-11IGM Motherboard Replacement: 步骤 7 中的图像 1,1
    • Ram chips are soldered onto motherboard and cannot be removed.
  8. Lenovo Flex 6-11IGM Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Disengage the cable located above the left speaker.
    • Disengage the ribbon cable located directly above the battery using the blue pick.
    • Disengage the battery cable directly above the ribbon cable housing.
    • Disengage the CMOS battery cable located to the right of the battery cable.
    • Remove the display cable located directly above the button battery.
    • Disengage the secondary display cable located directly to the left of the display cable.
  9. Lenovo Flex 6-11IGM Motherboard Replacement: 步骤 9 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the five 3.5 mm screws that secure the motherboard.
    • Using a Phillips #0 screwdriver, remove the one 3.5 mm screw that secures the Wi-Fi chip, located above the button battery.
  10. Lenovo Flex 6-11IGM Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the Wi-Fi chip located above the button battery from the motherboard.
    • Remove the motherboard from the case.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 1,037
