跳转到主内容
Lenovo Flex 3-1120 Speakers Replacement
你所需要的
  1. Lenovo Flex 3-1120 Speakers Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Speakers Replacement: 步骤 2 中的图像 1,2 Lenovo Flex 3-1120 Speakers Replacement: 步骤 2 中的图像 2,2
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Speakers Replacement: 步骤 3 中的图像 1,1
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Speakers Replacement: 步骤 4 中的图像 1,1
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Speakers Replacement, Speakers: 步骤 5 中的图像 1,1
    • Locate the speakers at the bottom left and right corners of the computer.
  6. Lenovo Flex 3-1120 Speakers Replacement: 步骤 6 中的图像 1,2 Lenovo Flex 3-1120 Speakers Replacement: 步骤 6 中的图像 2,2
    • Locate the two 1mm Phillips head screws on both speakers.
    • Remove both screws from each speaker.
  7. Lenovo Flex 3-1120 Speakers Replacement: 步骤 7 中的图像 1,2 Lenovo Flex 3-1120 Speakers Replacement: 步骤 7 中的图像 2,2
    • Locate where the two speaker wires join at the center of the computer.
    • Follow the wires directly upward to where they connect into the motherboard.
  8. Lenovo Flex 3-1120 Speakers Replacement: 步骤 8 中的图像 1,1
    • Using the spudger, pull the wire down and away from the motherboard to disconnect it.
结论
Geoff Bentz
于03/09/16注册
934 声望
创作了5篇指南
团队
UMass Dartmouth, Team 7-1, Catania Spring 2016 UMass Dartmouth, Team 7-1, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S7G1
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 7
总计 402
