跳转到主内容
Lenovo Flex 3-1120 Hard Drive Replacement
你所需要的
  1. Lenovo Flex 3-1120 Hard Drive Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Hard Drive Replacement: 步骤 2 中的图像 1,2 Lenovo Flex 3-1120 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Locate the hard drive in the bottom left of your computer.
  6. Lenovo Flex 3-1120 Hard Drive Replacement: 步骤 6 中的图像 1,2 Lenovo Flex 3-1120 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Locate the three 3.5mm Phillips screws on the corners of the hard drive.
    • Remove the three screws with a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Follow the wire out from the right side of the hard drive to locate where the hard drive connects to the motherboard.
  8. Lenovo Flex 3-1120 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Lift off the strip of tape securing the wire down to the computer.
  9. Lenovo Flex 3-1120 Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Pull the connector out of its port on the motherboard.
  10. Lenovo Flex 3-1120 Hard Drive Replacement: 步骤 10 中的图像 1,1
    • Lift the hard drive out from the computer.
结论
7等其他人完成本指南。
Geoff Bentz
于03/09/16注册
934 声望
创作了5篇指南
团队
UMass Dartmouth, Team 7-1, Catania Spring 2016 UMass Dartmouth, Team 7-1, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S7G1
4 名成员
创作了7篇指南
4条评论
How do you reload operating system.... for example windows 10?
supermac200 - 回复
How do I get Windows 10 working again after replacing hard drive on Lenovo Flex 3?
arcinko - 回复
Demo models of this do not have any SATA connector.
Elilla Shadowheart - 回复
That sata connector is the worst thing ever
dilleremail - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 38
总计 10,797
