跳转到主内容
Lenovo Essential G570 Fan Replacement
你所需要的
  1. Lenovo Essential G570 Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to unplug the cable could result in electric shock.
    • Turn the computer upside down.
  2. Lenovo Essential G570 Fan Replacement: 步骤 2 中的图像 1,2 Lenovo Essential G570 Fan Replacement: 步骤 2 中的图像 2,2
    • Locate the two switches that lock the battery.
    • Push the right switch outwards to unlock the battery.
  3. Lenovo Essential G570 Fan Replacement: 步骤 3 中的图像 1,2 Lenovo Essential G570 Fan Replacement: 步骤 3 中的图像 2,2
    • Push and hold the left switch outwards to unlock the battery.
    • Pull the battery away from the computer.
  4. Lenovo Essential G570 Fan Replacement, Back Panel: 步骤 4 中的图像 1,1
    • Turn the laptop over so that the bottom side is facing up.
  5. Lenovo Essential G570 Fan Replacement: 步骤 5 中的图像 1,1
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
  6. Lenovo Essential G570 Fan Replacement: 步骤 6 中的图像 1,3 Lenovo Essential G570 Fan Replacement: 步骤 6 中的图像 2,3 Lenovo Essential G570 Fan Replacement: 步骤 6 中的图像 3,3
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
  7. Lenovo Essential G570 Fan Replacement, Fan: 步骤 7 中的图像 1,2 Lenovo Essential G570 Fan Replacement, Fan: 步骤 7 中的图像 2,2
    • Carefully pull the fan's power connector from the laptop.
  8. Lenovo Essential G570 Fan Replacement: 步骤 8 中的图像 1,2 Lenovo Essential G570 Fan Replacement: 步骤 8 中的图像 2,2
    • Remove the three 5mm Phillips #1 screws holding the fan in place.
  9. Lenovo Essential G570 Fan Replacement: 步骤 9 中的图像 1,2 Lenovo Essential G570 Fan Replacement: 步骤 9 中的图像 2,2
    • Remove the fan by pulling it up and away from the computer.
结论
2等其他人完成本指南。
Lucio
于03/06/18注册
217 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 614
