简介
RAM should be replaced if the computer has memory issues. This is sometimes the case when the computer won't boot, or simply runs too slow for comfort.
工具
配件
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
a few of my screws are not coming out
Same here. I was able to easily remove the 2 middle screws but the rest were just wiggling in place and not coming out at all.
Denskwik K - 回复
I have the exact same problem. I dont know if it is because of the screws or if it is because I am an 11 year old.
Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
4等其他人完成本指南。
一条评论
maine apne lenovo g560 laptop me crucial 4gb ram add kiya lekin mera system format nahi ho raha h. mujhe kya karna chahiye mujhe email kare. vikasmaddeshiya056@gmail.com
