跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide details the steps necessary to remove single keys from the keyboard. Please follow this guide only if you are experiencing trouble with a few keys. If numerous keys aren't working, it may be time to replace the entire keyboard.
  1. Turn off the computer.
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position. Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Place your pointer finger under the key you want to remove. For extra leverage, use the thumb and rotate the key in the manner shown.
    • Place your pointer finger under the key you want to remove. For extra leverage, use the thumb and rotate the key in the manner shown.
  5. The key will come off with a popping sound.
    • The key will come off with a popping sound.
    • You will now be able to see the mechanism below the key. Clean this area using compressed air, then replace the key.
结论
To reassemble your keyboard, push the key back into the original spot.
6等其他人完成本指南。
Lawrence Downs
于2013年01月11日注册
335 信誉积分
创作了2篇指南
团队
Cal Poly, Team 18-40, Regan Winter 2013 Cal Poly, Team 18-40, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G40
5 名成员
创作了7篇指南
I used your guide to install the key, thank you. I bought my lenovo keys from this link below
http://www.replacementlaptopkeys.com/len...
keep up the good work.
Resteasy - 回复
Hello , you can buy single keys on this site:
http://www.laptopkey-europe.eu/
John Pohl - 回复
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 7
过去的30天: 19
总计 7,983
