跳转到主内容
Lenovo Essential G555-0873 CPU Replacement
你所需要的
  1. Lenovo Essential G555-0873 CPU Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lenovo Essential G555-0873 CPU Replacement: 步骤 2 中的图像 1,1
    • Lift from the notch until the back panel comes up.
  3. Lenovo Essential G555-0873 CPU Replacement, Fan: 步骤 3 中的图像 1,1
    • Disconnect the fan from the motherboard by pulling the plug shown in the picture.
  4. Lenovo Essential G555-0873 CPU Replacement: 步骤 4 中的图像 1,1
    • Unscrew the three 4.6mm screws shown in the picture.
  5. Lenovo Essential G555-0873 CPU Replacement: 步骤 5 中的图像 1,1
    • Gently lift the fan straight up until it is lifted out of the case.
  6. Lenovo Essential G555-0873 CPU Replacement, Heat Sink: 步骤 6 中的图像 1,1
    • Unscrew the four 7.3 mm screws shown in the picture.
    • Note that springs are attached to the screws. Do not remove the springs.
  7. Lenovo Essential G555-0873 CPU Replacement: 步骤 7 中的图像 1,2 Lenovo Essential G555-0873 CPU Replacement: 步骤 7 中的图像 2,2
    • Pull the heat sink assembly out of the laptop.
  8. Lenovo Essential G555-0873 CPU Replacement, CPU: 步骤 8 中的图像 1,2 Lenovo Essential G555-0873 CPU Replacement, CPU: 步骤 8 中的图像 2,2
    • Use a flat-head screwdriver on the hinge shown, and turn counter-clockwise to the unlock position
  9. Lenovo Essential G555-0873 CPU Replacement: 步骤 9 中的图像 1,1
    • Remove the CPU
    • There will be old thermal paste on the CPU and heat sink which should be wiped off using microfiber cloth.
    • Before putting the heat sink back in, a small droplet of thermal paste should be applied onto the center of the CPU.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 382
