跳转到主内容
Lenovo Essential B570 DVD Drive Replacement
你所需要的
  1. Lenovo Essential B570 DVD Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn over laptop.
    • Switch open the left battery lock.
    • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
  2. Lenovo Essential B570 DVD Drive Replacement: 步骤 2 中的图像 1,1
    • Hold the right battery lock open with one hand while removing the battery itself with the other.
  3. Lenovo Essential B570 DVD Drive Replacement, Back Panel: 步骤 3 中的图像 1,1
    • Loosen the five Philips screws that secure the panel.
    • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
  4. Lenovo Essential B570 DVD Drive Replacement: 步骤 4 中的图像 1,3 Lenovo Essential B570 DVD Drive Replacement: 步骤 4 中的图像 2,3 Lenovo Essential B570 DVD Drive Replacement: 步骤 4 中的图像 3,3
    • Prop open the cover with a plastic opening tool.
    • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
  5. Lenovo Essential B570 DVD Drive Replacement, DVD Drive: 步骤 5 中的图像 1,1
    • Unscrew the one 4 mm Phillips screw that is securing your DVD drive to the frame.
  6. Lenovo Essential B570 DVD Drive Replacement: 步骤 6 中的图像 1,2 Lenovo Essential B570 DVD Drive Replacement: 步骤 6 中的图像 2,2
    • Grab your DVD drive and pull outwards.
结论
团队
UMass Dartmouth, Team 4-5, Catania Fall 2015 UMass Dartmouth, Team 4-5, Catania Fall 2015 的会员
UMASSD-CATANIA-F15S4G5
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 16
总计 1,229
