跳转到主内容
Lenovo Edge 15 Keyboard Key Replacement
你所需要的
  1. Lenovo Edge 15 Keyboard Key Replacement, Keyboard Key: 步骤 1 中的图像 1,3 Lenovo Edge 15 Keyboard Key Replacement, Keyboard Key: 步骤 1 中的图像 2,3 Lenovo Edge 15 Keyboard Key Replacement, Keyboard Key: 步骤 1 中的图像 3,3
    • Using the plastic opening tool, pry off the key.
    • Observe the metal hooks. The position of the metal hooks determines where the plastic keys reside.
    • Pry off the plastic keyboard connector.
  2. Lenovo Edge 15 Keyboard Key Replacement: 步骤 2 中的图像 1,3 Lenovo Edge 15 Keyboard Key Replacement: 步骤 2 中的图像 2,3 Lenovo Edge 15 Keyboard Key Replacement: 步骤 2 中的图像 3,3
    • Separate the plastic keys.
    • The smooth part of both plastic keys always faces away from the keyboard.
  3. Lenovo Edge 15 Keyboard Key Replacement: 步骤 3 中的图像 1,3 Lenovo Edge 15 Keyboard Key Replacement: 步骤 3 中的图像 2,3 Lenovo Edge 15 Keyboard Key Replacement: 步骤 3 中的图像 3,3
    • Locate the metal hooks where the plastic keys are held in.
    • Insert the keys into the metal hook.
    • You may need to use a plastic opening tool or thin object to stretch the keys into the metal hook.
  4. Lenovo Edge 15 Keyboard Key Replacement: 步骤 4 中的图像 1,3 Lenovo Edge 15 Keyboard Key Replacement: 步骤 4 中的图像 2,3 Lenovo Edge 15 Keyboard Key Replacement: 步骤 4 中的图像 3,3
    • Evenly push the plastic keys into the metal hooks.
    • Evenly insert the key onto the plastic keys.
    • Use minimal force when pushing down on the keys.
    • Make sure the surface is free of any food, liquid, dust, etc.
结论
Fin.
4等其他人完成本指南。
Cody Griffith
于09/27/17注册
369 声望
创作了2篇指南
团队
Cal Poly, Team S8-G1, Banghart Fall 2017 Cal Poly, Team S8-G1, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S8G1
5 名成员
创作了7篇指南
1指南评论
Images are blurry, which makes this guide much harder to follow. Other images have too much light, making it impossible to see the grooves on the pieces. Additionally, the image of the smaller piece being inserted into the larger piece is incorrect. The smaller piece should be rotated 180 degrees. It should tuck in with the larger piece, creating a larger piece that is essentially flat. The instructions of “The smooth part of both plastic keys always faces away from the keyboard.“ is also misleading. The larger piece has some large grooves that the smaller piece gets tucked into. These grooves (which are obscured after the smaller piece is inserted) should face away from the keyboard. So really, the rough part of the larger piece faces away from the keyboard, not the smooth part. Put another way, the smaller piece can rotate inside the larger piece. The rods on the smaller piece (which the key attaches to) should rotate away from the keyboard. I’m not proud that I spent over an hour figuring this out.
Your Spam Filter Sucks - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 63
总计 6,314
