跳转到主内容
Lenovo B575-1450 Display Panel Replacement
你所需要的
  1. Lenovo B575-1450 Display Panel  Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 Display Panel  Replacement: 步骤 2 中的图像 1,2 Lenovo B575-1450 Display Panel  Replacement: 步骤 2 中的图像 2,2
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 Display Panel  Replacement: 步骤 3 中的图像 1,3 Lenovo B575-1450 Display Panel  Replacement: 步骤 3 中的图像 2,3 Lenovo B575-1450 Display Panel  Replacement: 步骤 3 中的图像 3,3
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 Display Panel  Replacement, Display Panel: 步骤 4 中的图像 1,2 Lenovo B575-1450 Display Panel  Replacement, Display Panel: 步骤 4 中的图像 2,2
    • Remove both screw covers from the bottom of screen bezel using a plastic spudger. The screws underneath will now be exposed
  5. Lenovo B575-1450 Display Panel  Replacement: 步骤 5 中的图像 1,1
    • Using the Phillips #0 Screwdriver, remove the two 4.3 mm screws holding the display to the front bezel.
  6. Lenovo B575-1450 Display Panel  Replacement: 步骤 6 中的图像 1,2 Lenovo B575-1450 Display Panel  Replacement: 步骤 6 中的图像 2,2
    • Separate the front bezel from the display panel using the plastic opening tool by gently prying around the edges and removing it.
  7. Lenovo B575-1450 Display Panel  Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using the tweezers carefully disconnect the ZIF connector by pulling cable away from front facing camera that is attached to the back bezel.
  8. Lenovo B575-1450 Display Panel  Replacement: 步骤 8 中的图像 1,3 Lenovo B575-1450 Display Panel  Replacement: 步骤 8 中的图像 2,3 Lenovo B575-1450 Display Panel  Replacement: 步骤 8 中的图像 3,3
    • Using the Phillips #0 Screwdriver, remove the six 4.3 mm screws that connect display screen to the rear bezel.
    • There are two screws in the bottom left and right corners of the frame.
  9. Lenovo B575-1450 Display Panel  Replacement: 步骤 9 中的图像 1,2 Lenovo B575-1450 Display Panel  Replacement: 步骤 9 中的图像 2,2
    • Using the Phillips #0 Screwdriver, remove the four 2.9 mm screws from each side of the bracket that holds the display panel in place.
  10. Lenovo B575-1450 Display Panel  Replacement: 步骤 10 中的图像 1,2 Lenovo B575-1450 Display Panel  Replacement: 步骤 10 中的图像 2,2
    • Lay display panel face down on the keyboard.
    • Peel back the flat wire that has the camera's ZIF connector until it is loose from the back of the display.
    • Carefully peel of the clear adhesive tape attached to the primary display ZIF connector using a plastic spudger.
  11. Lenovo B575-1450 Display Panel  Replacement: 步骤 11 中的图像 1,2 Lenovo B575-1450 Display Panel  Replacement: 步骤 11 中的图像 2,2
    • Place the metal tweezer tips between the ZIF connector and the wire-to-board connection.
    • Carefully separate ZIF wire-to-board connection by pulling metal tweezers in a downward motion.
    • Pull up on flat wire until display is completely disconnected.
    • Be very careful when separating ZIF connections . The ends of the ZIF wire connectors are delicate and can break easily.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 1,423
