跳转到主内容
Lenovo B575-1450 CD-ROM Drive Replacement
你所需要的
  1. Lenovo B575-1450 CD-ROM Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 CD-ROM Drive Replacement: 步骤 2 中的图像 1,2 Lenovo B575-1450 CD-ROM Drive Replacement: 步骤 2 中的图像 2,2
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 CD-ROM Drive Replacement: 步骤 3 中的图像 1,3 Lenovo B575-1450 CD-ROM Drive Replacement: 步骤 3 中的图像 2,3 Lenovo B575-1450 CD-ROM Drive Replacement: 步骤 3 中的图像 3,3
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 CD-ROM Drive Replacement, Back Panel: 步骤 4 中的图像 1,2 Lenovo B575-1450 CD-ROM Drive Replacement, Back Panel: 步骤 4 中的图像 2,2
    • The screws are captive to the back panel so they are not to be removed.
    • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
  5. Lenovo B575-1450 CD-ROM Drive Replacement: 步骤 5 中的图像 1,1
    • Using a plastic opening tool, pry the back panel from the laptop.
  6. Lenovo B575-1450 CD-ROM Drive Replacement: 步骤 6 中的图像 1,1
    • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
  7. Lenovo B575-1450 CD-ROM Drive Replacement, CD-ROM Drive: 步骤 7 中的图像 1,2 Lenovo B575-1450 CD-ROM Drive Replacement, CD-ROM Drive: 步骤 7 中的图像 2,2
    • Using the Phillips #00 Screwdriver, remove the 3.4 mm screw from the CD-ROM bracket.
    • This unlocks the CD-ROM drive from the computer
  8. Lenovo B575-1450 CD-ROM Drive Replacement: 步骤 8 中的图像 1,2 Lenovo B575-1450 CD-ROM Drive Replacement: 步骤 8 中的图像 2,2
    • Pry CD-ROM drive from laptop using a plastic opening tool.
    • Pull the CD-ROM drive the rest of the way out.
结论
一条评论
Can u please show me how to assemble or fix dvd drive lock mechanism for lenovo e49.
nukuvsh4 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 496
