跳转到主内容
Lenovo B575-1450 Back Panel Removal
你所需要的
  1. Lenovo B575-1450 Back Panel Removal, Battery: 步骤 1 中的图像 1,1
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 Back Panel Removal: 步骤 2 中的图像 1,2 Lenovo B575-1450 Back Panel Removal: 步骤 2 中的图像 2,2
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 Back Panel Removal: 步骤 3 中的图像 1,3 Lenovo B575-1450 Back Panel Removal: 步骤 3 中的图像 2,3 Lenovo B575-1450 Back Panel Removal: 步骤 3 中的图像 3,3
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 Back Panel Removal, Back Panel: 步骤 4 中的图像 1,2 Lenovo B575-1450 Back Panel Removal, Back Panel: 步骤 4 中的图像 2,2
    • The screws are captive to the back panel so they are not to be removed.
    • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
  5. Lenovo B575-1450 Back Panel Removal: 步骤 5 中的图像 1,1
    • Using a plastic opening tool, pry the back panel from the laptop.
  6. Lenovo B575-1450 Back Panel Removal: 步骤 6 中的图像 1,1
    • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 1,259
