跳转到主内容
Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement
你所需要的
视频概述
  1. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Switch off the laptop, disconnect the AC adapter, and remove the battery.
  2. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: 步骤 2 中的图像 1,2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: 步骤 2 中的图像 2,2
    • Remove the screws securing the Memory / HDD cover.
    • Slide the cover down and remove it.
  3. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: 步骤 3 中的图像 1,2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: 步骤 3 中的图像 2,2
    • To pop up the memory module you’ll have to spread latches on both sides of the slot.
    • MEMORY
    • Speed 1600 MHz / PC3L-12800
    • Technology DDR3L SDRAM SODIMM
    • Max Supported Size 16 GB
    • Form Factor SO-DIMM 204-pin
    • Slots Qty 2
    • Empty Slots 1
  4. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): 步骤 4 中的图像 1,3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): 步骤 4 中的图像 2,3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): 步骤 4 中的图像 3,3
    • Remove two screws securing the hard drive mounting bracked.
    • Slide the HDD to the left to disconnect it from the motherboard and remove it from the device.
    • Remove two screws on each side of the HDD to remove the mounting bracket.
    • Now you have to transfer the mounting bracket to the new HDD or SSD.
  5. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: 步骤 5 中的图像 1,2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: 步骤 5 中的图像 2,2
    • Remove the screw and disconnect the two coaxial antenna cables from the WiFi card.
    • Pop it up and remove it from the slot.
    • Wireless N M.2, or Next Generation Form Factor (NGFF) Card.
  6. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: 步骤 6 中的图像 1,3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: 步骤 6 中的图像 2,3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: 步骤 6 中的图像 3,3
    • Complementary Metal-Oxide-Semiconductor (CMOS) aka Real-Time Clock (RTC)
    • CR2032
  7. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement: 步骤 7 中的图像 1,1
    • That's all.
结论
3等其他人完成本指南。
ZFix
于12/09/13注册
191,368 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,542篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 20
过去 30 天: 64
总计 7,279
