跳转到主内容
Lenovo A8-50 Motherboard and Speaker Replacement
你所需要的
  1. Lenovo A8-50 Motherboard and Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover by prying it open with the metal spudger tool.
  2. Lenovo A8-50 Motherboard and Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the two screws with a PH000 head screwdriver.
    • Keep all your screws in one place.
  3. Lenovo A8-50 Motherboard and Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the metal piece.
    • Keep this piece safe, as you will need it to reassemble the device again.
  4. Lenovo A8-50 Motherboard and Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the battery by lifting it up using a plastic spudger.
  5. Lenovo A8-50 Motherboard and Speaker Replacement: 步骤 5 中的图像 1,1
    • Disconnect the cable from the connection.
    • Be careful not to tear or bend the cable.
  6. Lenovo A8-50 Motherboard and Speaker Replacement, Motherboard and Speaker: 步骤 6 中的图像 1,1
    • Unscrew the 5 black screws, and the 9 silver screws with a PH000 head screwdriver.
    • Set aside carefully.
  7. Lenovo A8-50 Motherboard and Speaker Replacement: 步骤 7 中的图像 1,2 Lenovo A8-50 Motherboard and Speaker Replacement: 步骤 7 中的图像 2,2
    • Remove the two black panels and the clear circle piece.
  8. Lenovo A8-50 Motherboard and Speaker Replacement: 步骤 8 中的图像 1,1
    • Lift up the motherboard carefully, ensuring that you lift the speaker housing and the motherboard together
  9. Lenovo A8-50 Motherboard and Speaker Replacement: 步骤 9 中的图像 1,1
    • Lift the bottom speaker piece up carefully
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 1,271
