跳转到主内容
Lenovo A7-50 A3500 Battery Replacement
你所需要的
  1. Lenovo A7-50 A3500 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo A7-50 A3500 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove SD and SIM card from device
  2. Lenovo A7-50 A3500 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove screw with a simple coss screwdriver
  3. Lenovo A7-50 A3500 Battery Replacement: 步骤 3 中的图像 1,3 Lenovo A7-50 A3500 Battery Replacement: 步骤 3 中的图像 2,3 Lenovo A7-50 A3500 Battery Replacement: 步骤 3 中的图像 3,3
    • Remove cover. Starting from the point where you removed the screw.
    • Disassemble cover clockwise.
  4. Lenovo A7-50 A3500 Battery Replacement: 步骤 4 中的图像 1,2 Lenovo A7-50 A3500 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove screw with simple screw driver
    • Remove metal holder as shown in picture
  5. Lenovo A7-50 A3500 Battery Replacement: 步骤 5 中的图像 1,1
    • Remove connection cable as shown.
  6. Lenovo A7-50 A3500 Battery Replacement: 步骤 6 中的图像 1,1
    • Disassemble battery pack. This might require a bit of pressure as it is glued
结论
4等其他人完成本指南。
Stefan K
于01/13/18注册
469 声望
创作了2篇指南
一条评论
Hi my tablet is similar to this
So the problem with my tablet is water went in. It does charge but it refuses to turn in, so I was trying to look for the reset pin hole but I can't find it on the tablet. Do you know how it can be fixed?
Blessing Bepe - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 2,701
