跳转到主内容
Lenovo A7-40, A7-50 A3500 Factory Reset
你所需要的
视频概述
  1. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: 步骤 1 中的图像 1,3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: 步骤 1 中的图像 2,3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: 步骤 1 中的图像 3,3
    • 1. Switch of the tablet. If the device freezes, you can use a reset hole under the memory card reader cover.
    • 2. Press and hod: Volume Up + Volume Down + Power buttons.
    • 3. In the Recovery menu, use the Volume Down button to move the highlight and the Volume Up to select.
    • 4. Choose one by one: "wipe data/factory reset", "Yes -- delete all user data" and finally "reboot system now".
  2. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: 步骤 2 中的图像 1,3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: 步骤 2 中的图像 2,3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: 步骤 2 中的图像 3,3
    • 1. Switch off the tablet.
    • 2. Press and hold the Volume Up and Power On keys.
    • 3. When you feel release only the Power button. Now your device is in Factory mode.
    • 4. Use the Volume Up/Down keys for movement and the Power key for select.
    • 5. Select ¶§ eMMC (Clean eMMC)
    • Did you do it successfully?
结论
33等其他人完成本指南。
ZFix
于12/09/13注册
192,056 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,525篇指南
17条评论
let me try and see
usman aleeyu - 回复
Is it applicable to my lenovo a516?
valvinzon - 回复
yes it works thanks
abdullahjanajy - 回复
Love you so much goodnight baby
Van Prince -
Well thanks!! I was worried about my tab and now i can fix easily tab without paying others to fix my tab. Thank you again :))
Christian Lemuel Espenilla - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 31
过去 30 天: 97
总计 106,459
