跳转到主内容
Lenovo 300e Chromebook USB and Charging Ports Replacement
你所需要的
  1. Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: 步骤 1 中的图像 1,3 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: 步骤 1 中的图像 2,3 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook USB and Charging Ports Replacement: 步骤 2 中的图像 1,3 Lenovo 300e Chromebook USB and Charging Ports Replacement: 步骤 2 中的图像 2,3 Lenovo 300e Chromebook USB and Charging Ports Replacement: 步骤 2 中的图像 3,3
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: 步骤 3 中的图像 1,3 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: 步骤 3 中的图像 2,3 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: 步骤 3 中的图像 3,3
    • Remove three 5 mm screws from the USB board using a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook USB and Charging Ports Replacement: 步骤 4 中的图像 1,3 Lenovo 300e Chromebook USB and Charging Ports Replacement: 步骤 4 中的图像 2,3 Lenovo 300e Chromebook USB and Charging Ports Replacement: 步骤 4 中的图像 3,3
    • Detach the white and blue ribbon cable from its cable connector on the USB board.
    • Remove the USB board from the laptop.
结论
另外一个人完成了本指南。
一条评论
Do you have same instructions for Lenovo 300e Gen2, I opened and usb ports are soldered with the motherboard, I am having some troubles to replace the usb c, any recommendation?
Juan Raul Hernandez - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 44
总计 1,454
