你所需要的
Remove all 9 screws on the back of the Chromebook with a Phillips #0 screwdriver
Use an opening tool such as a spudgerand carefully work your way around the laptop to remove the back cover
Remove the black tape covering the connector, then using a spudge tool, carefully unplug the battery from the motherboard
Disconnect the Trackpad Cable by lifting the Connector.
Remove the 3 screws holding in the top of the trackpad with a Phillips #0 screwdriver
There are 3 tabs (2 at the bottom and 1 at the top left of the trackpad), using the Spudger, push the tabs to remove the Trackpad from the case.
