跳转到主内容
Lenovo 300e Chromebook 2nd Gen Battery Replacement
你所需要的
  1. Lenovo 300e Chromebook 2nd Gen Battery Replacement, Opening The Chromebook: 步骤 1 中的图像 1,3 Lenovo 300e Chromebook 2nd Gen Battery Replacement, Opening The Chromebook: 步骤 1 中的图像 2,3 Lenovo 300e Chromebook 2nd Gen Battery Replacement, Opening The Chromebook: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    Phillips #0 Screwdriver
    $5.49
    购买
    • Make sure you power off your Chromebook first as you will be disconnecting the battery!
    • Remove all 9 screws on the back of the Chromebook with a Phillips #0 screwdriver
    • The screws circled on this Chromebook's back casing are all identical!
    • Use an opening tool such as a spudger and carefully work your way around the laptop to remove the back cover
  2. Lenovo 300e Chromebook 2nd Gen Battery Replacement, Disconnect the Battery: 步骤 2 中的图像 1,2 Lenovo 300e Chromebook 2nd Gen Battery Replacement, Disconnect the Battery: 步骤 2 中的图像 2,2
    • Remove the black tape covering the connector, then using a spudge tool, carefully unplug the battery from the motherboard
  3. Lenovo 300e Chromebook 2nd Gen Battery Replacement, Remove the battery: 步骤 3 中的图像 1,2 Lenovo 300e Chromebook 2nd Gen Battery Replacement, Remove the battery: 步骤 3 中的图像 2,2
    • Remove the 4 screws holding in the battery and set them aside
    • Make sure to separate the screws for the battery from the screws for the backing that were removed in the first step!
结论
2等其他人完成本指南。
Zachary Costello
于07/15/21注册
153 声望
撰写一个指南
团队
Zeeland Public Schools Zeeland Public Schools 的会员
Business
2 名成员
创作了1篇指南
一条评论
It should be mentioned that "newer" models of this particular Chromebook are/have been released. The Chromebooks' battery compartment's design have been slightly modified in that the battery compartment are now reversed.
So, since the battery's connector cable is so short, it's impossible to twist it to fit.
So, make sure you're getting the correct battery for the correct "model".
FYI, the "older" models have the power button close to the back corner of the device, and the "newer" models have the power button near the middle of the device.
Christopher Mali-Martinez - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 54
总计 2,471
