跳转到主内容
Lenovo 100s Chromebook-11IBY Speaker Replacement
你所需要的
  1. Lenovo 100s Chromebook-11IBY Speaker Replacement, Speakers: 步骤 1 中的图像 1,1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Speaker Replacement: 步骤 2 中的图像 1,1
    • Use a #0 Phillips screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Speaker Replacement: 步骤 3 中的图像 1,2 Lenovo 100s Chromebook-11IBY Speaker Replacement: 步骤 3 中的图像 2,2
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Speaker Replacement: 步骤 4 中的图像 1,3 Lenovo 100s Chromebook-11IBY Speaker Replacement: 步骤 4 中的图像 2,3 Lenovo 100s Chromebook-11IBY Speaker Replacement: 步骤 4 中的图像 3,3
    • Locate the two sticker-like connecting wires (for the keyboard and touchpad).
    • Carefully unplug the orange circled (keyboard) wire from the keyboard plate.
    • Carefully unplug the yellow circled (touchpad) wire from the keyboard plate.
    • Then lift the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Speaker Replacement: 步骤 5 中的图像 1,1
    • Locate the cable attaching the left speaker to the motherboard and unplug it by hand.
    • Then unplug the cable attaching the right speaker by hand.
  6. Lenovo 100s Chromebook-11IBY Speaker Replacement: 步骤 6 中的图像 1,2 Lenovo 100s Chromebook-11IBY Speaker Replacement: 步骤 6 中的图像 2,2
    • Carefully pry the speaker up and free of the two notches holding it in place.
    • Remove the speaker.
  7. Lenovo 100s Chromebook-11IBY Speaker Replacement: 步骤 7 中的图像 1,1
    • Repeat steps 5 & 6 in order to remove the right speaker.
结论
另外一个人完成了本指南。
Milton Perez
于03/09/17注册
630 声望
创作了5篇指南
团队
USF Tampa, Team S7-G2, Cagle Spring 2017 USF Tampa, Team S7-G2, Cagle Spring 2017 的会员
USFT-CAGLE-S17S7G2
1 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 506
